Steph1981
Apr 27, 2020Follower
Wn3000 v3
Wondering if anyone can help long story short had router about 2 years no problems woke up this morning and suddenly not working done factory reset the lot and still no internet. It connects and says ...
Apr 27, 2020Guru - Experienced User
the wn3000rpv3 is a wireless range extender. Did you re-run setup with your router?
- TheOldeADJun 29, 2020Aspirant
I see that old name of the extender - do i do it with that? Sorry - not sure what my next step is?
- plemansJun 29, 2020Guru - Experienced UserDid you factory reset it?
whats the "old name"? are you talking the default ssid (name) and password the extender came with?
Did you pull up the support site? it has manuals, install guides, and even videos.
