Steph1981
Apr 27, 2020Follower
Wn3000 v3
Wondering if anyone can help long story short had router about 2 years no problems woke up this morning and suddenly not working done factory reset the lot and still no internet. It connects and says ...
TheOldeAD
Jun 29, 2020Aspirant
Can anyone help me? I have a WN300 wifi range extender. It has worked great but I got a new rpouter. How do i get the range extender to take on the new password?
Steph1981 wrote:
Wondering if anyone can help long story short had router about 2 years no problems woke up this morning and suddenly not working done factory reset the lot and still no internet. It connects and says it’s ready to use but still no internet connection.
Sorry I’m not very technical
Thanks in advance
Steph
Jun 29, 2020Guru - Experienced User
Factory reset it and follow the install guide.
Push and hold reset for 7-15 seconds while its powered on. That'll reset it.
Then just follow the install guide.
https://www.netgear.com/support/product/WN3000RP.aspx
If you have further problems, please start your own thread. Thanks!
