NetGearUser1234
Dec 16, 2012Aspirant
WN3000RP - can't access mywifiext.net
If I type http://www.mywifiext.net in to FireFox, I get automatically redirected to http://support.netgear.com/
badgerjr
Dec 25, 2013Aspirant
Also, if you are windows 7, open the internet connections window, select create network map, mouse over the WN3000RP and you should see the IP address. Type that number into the address bar and use admin and the user name and password as the password.
