NetGearUser1234
Jan 20, 2013Aspirant
WN3000RP - connection v. unstable if "owner PC" is online
My set up: PC #1 -- connects to a wireless modem/router PC #2 -- uses WN3000RP to connect to the wifi modem/router If PC #1 is online, then PC #2 cannot connect to the internet. If PC #1 i...
NetGearUser1234
Jan 21, 2013Aspirant
The wireless wifi modem/router is called a D-Link DSL-2640R, and its user guide can be found here -
http://www.bryana.talktalk.net/public/DSL-2640R%20User%20Guide.pdf
On one of the modem/router's settings webpage, I can see the following information:
Router IP Address = 192.168.1.1
Enable DHCP Server = true
DHCP IP Address Range = 192.168.1.2 to 192.168.1.254
The broadband service provider is called TalkTalk. If I run the ipconfig command on PC #2 (which is the "child PC" - the one that accesses the modem/router via the NetGear wifi extender), I get these results -
Windows IP Configuration
Host Name . . . . . . . . . . . . : PC2
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : dlink.com
Wireless LAN adapter Wireless Network Connection 2:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Microsoft Virtual WiFi Miniport Adapter
Physical Address. . . . . . . . . : (OK to remove this info?)
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . : dlink.com
Description . . . . . . . . . . . : Atheros AR9285 Wireless Network Adapter
Link-local IPv6 Address . . . . . : (OK to remove this info?) (Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.3(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 17 January 2013 21:59:34
Lease Expires . . . . . . . . . . : 18 January 2013 21:59:34
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 335554125
DHCPv6 Client DUID. . . . . . . . : (OK to remove this info?)
DNS Servers . . . . . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection* 12:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
DHCP Enabled. . . . . . . . . . . : No
IPv6 Address. . . . . . . . . . . : (OK to remove this info?)(Prefe
rred)
Link-local IPv6 Address . . . . . : (OK to remove this info?)(Preferred)
Default Gateway . . . . . . . . . : ::
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter isatap.dlink.com:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Tunnel adapter isatap.{(OK to remove this info?)}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Thanks a lot for any assistance on this issue - it would be much appreciated.
rred)
