NetGearUser1234
Jan 20, 2013Aspirant
WN3000RP - connection v. unstable if "owner PC" is online
My set up: PC #1 -- connects to a wireless modem/router PC #2 -- uses WN3000RP to connect to the wifi modem/router If PC #1 is online, then PC #2 cannot connect to the internet. If PC #1 i...
Advertman
Jan 27, 2013Aspirant
This is something i did not even noticed before the closest error i got was one where some devices could not connect but after a reboot all devices could connect this was on a thomson 780wl router some times i even had te delete the dhcp ipadres of the device that could not connect.
I would like to know what is your % of reception you get try to get above 30%
from your story it looks like the wnr3000rp is used as 1 ipadress and does not put 2 dhcp ipadresses through at the same time!
Have you tryed a firmware upgrade of the D-link?
Greets
Greets
