donfisher
May 11, 2011Aspirant
WN3000RP - purchase and review
I've been waiting for the WN3000RP since CES in January. Supposedly available but not seeing on any of the major web sites - Amazon, Frys Electronics, BestBuy. Have found on some web sites that not ...
Jack_
May 24, 2011Aspirant
No, this is intentionally. It's called: "getting to the 'hijack page' ".
cuclone3d wrote: Why it would not bring it up with the URL is just weird.
Try it... If it resolves your problem, then you know what is causing it (maybe too short key life time??).
As for the random internet connection dropping, they suggested I use WPA instead of WPA2.... not happening.
All depends what channels are in use by other networks in your area. The game is to use a channel that is as far as possible from other networks (both sides).
They said channel 11 is on of the better ones to try. I will test that out. Not really sure it will help.
Cascading repeaters AND using DHCP is really pushing it. Apart from very low throughput, you should really try to solve that problem otherwise (thought about Powerline adapters or plain old cabling?)
I also have to figure out why the second extender would not give me an IP address when connected to the first extender.
