donfisher
May 11, 2011Aspirant
WN3000RP - purchase and review
I've been waiting for the WN3000RP since CES in January. Supposedly available but not seeing on any of the major web sites - Amazon, Frys Electronics, BestBuy. Have found on some web sites that not ...
Jack_
May 24, 2011Aspirant
I'm personally not familiar with this new device and I may therefore have it wrong. But Netgear devices have this feature that when using a URL address, you get (after reset and before applying any settings) into a wizard or other screen that normally assists you in setting up the device. This is called the 'hi-jack screen'. After that initial screen, any further menu access will bring you to the regular menu of the device. To sidestep the initial 'hi-jack screen' you can enter the IP address of the device or the exact menu URL into your browser.
cuclone3d wrote: Really? Then why do they tell you in the setup instructions to go to www.mywifiext.net to make configuration changes after the initial setup?
Cascading repeaters means you're on your own, mate.....:eek:
Nope, that is not the problem. It appears to be that this happens when I am trying to cascade the repeaters.
This requirement looks perfect to me for an XAVN2001: Powerline Wireless Extender setup. You also need an XAV2001 connected by patchcable to the router.:cool:
Cabling really won't work unless i want to buy another wireless router or access point that can connect to the main router via cabling since we need the wireless for visitors.
