EmilG
Aug 15, 2011Novice
WN3000RP - so close but no cigar
I can't quite get this thing working, I get "can't connect to the internet". Here's my setup: Router WNDR3400 Router -> wireless -> PC Router -> wireless -> WN3000RP -> wireless -> iPad Via t...
EmilG
Aug 16, 2011Novice
jmizoguchi wrote: WLAN- WIRELESS
LAN - commonly connected with ethernet cable.
Ok, since I was linked via wireless on both sides (router->extender and extender->iPad) that's why LAN showed link down, got it!
I'll try factory reset tonight (or maybe tomorrow night) and go through it again. I'll first try the simple WPA method others have had no problems with (although I tried it before that way before). If no luck I'll do manual with a wired link to a pc.
Thanks
