Steev5's avatar
Steev5
Follower
May 26, 2012
WN3000RP and apple remote app
Hi - have successfully installed wifi extender but try as I might I cannot get this app to connect to my iTunes home sharing account/library - it works perfectly via my usual wifi connection but refuses to find the library when I switch to the ext network - any clues gratefully accepted. :D
1 Reply
  • Daft point, but I would first check with another device that you can access the Internet when connected to your WN3000RP.
