tdnb
Jul 18, 2011Aspirant
WN3000RP antenna changing?
Can you swap out the antenna in this product for stronger antenna? Various websites say the antenna are removable, but it seems that they sit in a molded sleeve and cannot be changed. Anyone know fro...
Ali1980
Jun 13, 2017Aspirant
Yes it is possible I accidently pulled my antenna out the other day so decided to take it apart it has the mini antenna connections on the circuit board inside as you would find In a laptop so if you get a U.FL Mini PCI to RP-SMA Pigtail Antenna WiFi Cable and then you can connect a normal external wifi antenna. Hope this helps
