paradoxsj
Apr 12, 2012Aspirant
WN3000RP believes it has no IP address those status screen says otherwise
If the setup and config isnt bad enough...NOW the device acts as if it has not IP address so when any device connects to it, it has not access. Logging into the deive under shows it has an IP add...
paradoxsj
Apr 13, 2012Aspirant
jmizoguchi wrote: where you able to ping router and google dns?
What does google DNS have to do with my access point connection to my router and getting a IP address?
Yes the router is pingable...in addition, the nework is closed so google DNS does not come in to playl
