paradoxsj
Apr 12, 2012Aspirant
WN3000RP believes it has no IP address those status screen says otherwise
If the setup and config isnt bad enough...NOW the device acts as if it has not IP address so when any device connects to it, it has not access. Logging into the deive under shows it has an IP add...
jmizoguchi
Apr 13, 2012Virtuoso
if you can ping router then should able to ping external IP
did you ping google or did not even tried?
