paradoxsj
Apr 12, 2012Aspirant
WN3000RP believes it has no IP address those status screen says otherwise
If the setup and config isnt bad enough...NOW the device acts as if it has not IP address so when any device connects to it, it has not access. Logging into the deive under shows it has an IP add...
paradoxsj
Apr 13, 2012Aspirant
jmizoguchi wrote: you did not answer to yes, no to the questions.
assuming you had static IP..
I've given the AP a static address AND I have allowed DHCP to assign it an address. Either way, it gets the same address as this is how my router is configured.
I can ping the router regadrless of having a Static or DHCP assigned address.
