paradoxsj
Apr 12, 2012Aspirant
WN3000RP believes it has no IP address those status screen says otherwise
If the setup and config isnt bad enough...NOW the device acts as if it has not IP address so when any device connects to it, it has not access. Logging into the deive under shows it has an IP add...
jmizoguchi
Apr 13, 2012Virtuoso
paradoxsj wrote: 192.x.x.2 & 192.x.x.10
there is useless to hide private ip... :)
2 as extender and 10 as PC ?
10 was static IP that you chosen for the PC correct?
