paradoxsj
Apr 12, 2012Aspirant
WN3000RP believes it has no IP address those status screen says otherwise
If the setup and config isnt bad enough...NOW the device acts as if it has not IP address so when any device connects to it, it has not access. Logging into the deive under shows it has an IP add...
paradoxsj
Apr 19, 2012Aspirant
I was able to figure out that the issue was/is. There is what appears to be a bug in the latest firmware. It manifest itself one or two ways.
1. IF you are using the ACL feature of a Netgear router the extender will not be able to assign IP address to the devices that connect to it. ( I beleive the reason is it isn't capable of passing on its MAC address to the router properly) You must turn ACL off for it to work.
2. IF you are using DHCP on your router AND address reservation AND you only have the exact number of IP address that you need being assigned out then the extender will not be able to assigne out the predefined address reservation you've set. You must expand your DHCP pool beyond the exact number of oredefined IP address and it will select from them. (And again in this case, I beleive the reason is it isn't capable of passing on its MAC address to the router properly)
Take aways...
Turn off ACL and expand your DHCP pool.
Netgear Tech Supp was no help this..the simply wanted to follow their script.... :-(
Take aways...
