davidk111
May 05, 2014Follower
WN3000RP devices will not connect
Setup my WN3000RP. Everything went well. In the wizard I can see it is connected to my router and all the lights are green. But when I try to connect up my laptop or cell to the extender they will not connect. It just sits forever on "Obtaining IP address"
Any ideas on what is wrong?:confused:
1 Reply
- cheechoopAspirantReset your netgear extender and then set it up again. If it still doesn't work, check if other devices can connect to the extender to rule out the possibility of pc/extender issue. Step By Step Guide To Setup NETGEAR WN3000RP
