lodeon
Jun 30, 2011Novice
WN3000RP disconnects
Just picked up my wn3000rp and hooked it up to my d-link dir-855 main router. All my wireless clients can connect to the extended network without any problems but... after 10 minutes the connection...
Miketyson
Feb 12, 2012Aspirant
Under 'Advanced' in 'Wireless Setting' you can find the 'Setup Access List' button. You should check 'Turn Access Control On' and add the list of all MAC Addresses of the devices allowed to access the WN3000RP (all your devices you want to use with the extender)
This way all the other devices trying to access the extender for a WPS authentication will be refused prior to try the connection.
