lodeon
Jun 30, 2011Novice
WN3000RP disconnects
Just picked up my wn3000rp and hooked it up to my d-link dir-855 main router. All my wireless clients can connect to the extended network without any problems but... after 10 minutes the connection...
Miketyson
Feb 16, 2012Aspirant
Yes this is a native problem, but it is an issue only if you have WPS devices in your neighbor and it can be solved with the MAC access list. Besides this the device works very well and is very easy to implement.
