lodeon
Jun 30, 2011Novice
WN3000RP disconnects
Just picked up my wn3000rp and hooked it up to my d-link dir-855 main router. All my wireless clients can connect to the extended network without any problems but... after 10 minutes the connection...
nhann
Oct 13, 2015NETGEAR Employee Retired
Yes, you can edit these in the future
Shick31
Oct 13, 2015Aspirant
Excellent. Some devices are showing 2 MAC addresses, one is just labeled MAC and the other Virtual MAC - which should I use?
- nhannOct 13, 2015NETGEAR Employee Retired
Add both MAC addresses to your router's MAC filter
- Shick31Oct 13, 2015Aspirant
Cheers, thank you so much. Will let you know how it goes tomorrow.
- Shick31Oct 14, 2015Aspirant
Applied a MAC filter, added all the addresses and it the connection dropped 5 minutes later!
- nhannOct 14, 2015NETGEAR Employee Retired
You can also check with EE to see if it's an issue with their router's firmware
