lodeon
Jun 30, 2011Novice
WN3000RP disconnects
Just picked up my wn3000rp and hooked it up to my d-link dir-855 main router. All my wireless clients can connect to the extended network without any problems but... after 10 minutes the connection...
nhann
Oct 13, 2015NETGEAR Employee Retired
Add both MAC addresses to your router's MAC filter
Shick31
Oct 14, 2015Aspirant
Applied a MAC filter, added all the addresses and it the connection dropped 5 minutes later!
- nhannOct 14, 2015NETGEAR Employee Retired
You can also check with EE to see if it's an issue with their router's firmware
- Shick31Oct 20, 2015Aspirant
I've rung them numerous times and tried pretty much everything they've suggested, and assured me will fix the problem, except move the router to the main BT socket. But seeing as they keep saying it's not an issue with the line, I can't see how that will make a difference. Perhaps it's time to change ISP. Anyway, thank you all for your help.
