NeoGeo's avatar
NeoGeo
WN3000RP dont get connected or to mywifiext.net
hello,
the situation:
if i connect from my laptop to the 3000 i have to enter AS FIRST! 00000000.
where the hell does this stand? are you crazy guys?
nowhere stands in the manual ANYTHING about 8 zeros!
as next step i chose Netgear_ext without encryption (NONE).
tara ... search search search .. NOTHING - connection failed.
i tried it after with a network cabel directly plugged into the 3000.
i get an IP from the 3000 but i can not connect to www.mywifiext.net
if i find no solution today - the WN3000RP goes back to the dealer tomorrow.
the manual is totaly worthless and horrible!
1 Reply
  • OKEY STOP
    THE INTEL PRO WIFI SOFTWARE CAUSED THE PROBLEM.
    IF I CONNECT VIA WIFI DIRECTLY IN WINDOWS ... it WORKS!
