7stud
Jul 29, 2011Aspirant
WN3000RP extender -- computer can't see extender network
Hi, After doing a WPS setup(click WPS button on router, click WPS button on extender), my imac 10.6.7 can't see ANY networks with '_EXT' on the end of the name. Namely, my imac can't see a network...
jmizoguchi
Jul 31, 2011Virtuoso
What do mean by 'standard' encryption? Today, I'd say WPA2-PSK (AES) is the standard. But of you are using WinXP and/or an older piece of hardware, then you may need to use WEP.
WPA,WPA2,WEP is encryption over WPS setup user has issue with Mac
