Beeky
Dec 15, 2012Aspirant
WN3000RP Extender connection mismatch issues
I have just bought a WN3000RP. Followed the instructions to the letter. I am using this in conjunction with a bthomehub router. I have ensured bot router and extender are WPA2 as advised in other foru...
Beeky
Dec 17, 2012Aspirant
Ok I have tried to access the www.mywifiext.net as advised in the instructions to manually set up the extender but for some reason I cannot access the web so I can't check whether the passphrase on the extender is the same as the BT router. I only get two lights on the extender the two middle lights the link rate light won't show up and neither does the WPS light. I did change the router for a new one at PC World but still with no success. Clearly it either something I am doing wrong or the equipment is not compatible. My Bt router is about 3 years old but I wouldn't have thought this should make a difference. Help!!!!
