Emmmy
Nov 16, 2012Follower
WN3000RP extender not connecting to router
My router is connected to the internet and my PC is connected to my netgear WN3000RP extender but I cant get the extender to connect to the router. It has been working for months before now. The troub...
Blach
Nov 19, 2012Aspirant
Got the exact same problem. Today I installed a new router which is working flawless both with cable and WIFI. My problem is my extender doesn't work now.
I've done factory reset and tried WSP and manual setup, but the extender won't connect to the router. The routers WIFI show up on the list, but it won't connect for some reason... The installation fails on the last step, where it tried to connect (after the 2 minut wait bar). WSP doesn't work either, I activate it on the router, then on the extender. Then it just times-out after a minut or so.
It worked fine with my old setup.
New setup: Cisco EPC3925
Old setup: D-LINK DIR-655
