CarrotCake
Apr 30, 2022Aspirant
WN3000RP Extender Password Issue
Model: WN3000RP Firmware: V1.0.2.64_1.1.86 I initially set up the extender and connecting to the router wasn't an issue. But when I went to enter the password (that should be the same as my rout...
Apr 30, 2022Guru - Experienced User
are you connecting it to the router using wps?
if so, factory reset the extender again (push and hold reset for 7-15 seconds while powered on), then install it using the installation assistant.
- CarrotCakeApr 30, 2022Aspirant
Hello plemans ,
Thank you for the response. Yes we attempted to use WPS and just tried to use the installer assistant. The netgear page that pops up didn't load but we were still able to access the installer assistant and connect to the router. When we enter the passphrase it says our network requires a WPA2 password. I attempted to go to the mywifi internet page while on the extender but it wasn't working. Would I need a PC for this process?
- plemansApr 30, 2022Guru - Experienced User
It can sometimes be easier/smoother on a pc/laptop.
What route are you connecting it to?
Are you using wpa2 on the router?
plemans Could you expand on what you mean by what route and if I'm using WPA2? The router we are using is Xfinity. Our wifi says its WPA2/WPA3.
