JK747
Oct 08, 2013Follower
WN3000RP Firmware bug in 1.0.1.36 causing lock up after 7 days
Hi Netgear Tech Support, I am using the WN3000RP with latest firmware 1.0.1.36 for several months. Unfortunately the 1.0.1.36 keeps locking up after about 7..10 days. This means you have to reset ...
roger_holbrook
Nov 26, 2013Aspirant
Has any one installed the .36 firmware without any problems. If not I will probably wait for the next release. NetGear replied to a request I made as to whether I should install it. They said not to install unless I am having problems. I get periodic dropped connections but they are only a nuisance and may be due to weak signals? I absolutely can not use a CHROMECAST and 2 ip cameras at the same time with only 5 FPS with the current firmware.
JK747's problem is worse than mine.
