uadmirin's avatar
uadmirin
Novice
Sep 03, 2011
WN3000RP Help.
I hooked up the extender this morning and it is working perfectly except for one computer. I am getting 5 bars on two laptops and a good signal on a ps3. However, I have one more laptop that will not connect to the network.
It is running Vista. I select the extender to connect to which is at 5 bars. It says connecting then it will ask for my pass phrase. I enter my pass phrase then it says it cannot connect to the extender.
I keep getting the same error message. Not sure what to do. Thanks for the help!
1 Reply
