ravidesai1406
Dec 08, 2021Tutor
WN3000RP Link Status is blank
Team, My WiFi extender was working perfectly fine till yesterday. However, suddenly the LINK STATUS light has gone blank. I tried everything, including factory reset and connecting all again....
- Dec 10, 2021There was some issue with my main WIFI ... That got resolved and the extender is working perfectly fine.
Dec 09, 2021Guru - Experienced User
What router are you connecting it to?
what method of setup are you using? WPS or the installation assistant?
- ravidesai1406Dec 09, 2021TutorRouter - Tp-link wireless router
Method - installation assistant through windows- plemansDec 09, 2021Guru - Experienced User
what tp-link router? They make a lot of them.
During setup, is the extender able to see the tp-link's wireless?
What does it show on its status page after it goes through setup? (maybe the led's bad)
- ravidesai1406Dec 10, 2021TutorThere was some issue with my main WIFI ... That got resolved and the extender is working perfectly fine.
