jvosmo's avatar
jvosmo
Follower
Dec 20, 2012
WN3000RP locks up
I have a Netgear wn30000rp extender that locks up about once per day. I can still connect to it, but I have no internet connection. The internet is still connected on the main router. Temporary solution is to power cycle it. Is there any permanent solution for this?
  • Yeah it happens to me all the time. but i think this has to do with the dhcp addressing with your main router, in most cases it happens ones a week sometimes longer, there fore i installed a wireless on off switch to reboot and turn the extender off and on again. sometimes it does not work at once and have to do it twice in a row. it seems that since some new firmware it got less it used to do this every day ;) maybe it's something the main routers can't handle the ipadress sometimes is taken and it keeps it that way. If you do nothing it can take hours so turning the extender on and off is faster. i have connected 4 devices and main router is a speedtouch 780WL.
  • My one locks up every 24/48 hrs you can still see it it as a valid wifi device but can not pass traffic, needs a main power on/off to kick it back into action, tried re-programming several times but still locks up.
  • Mine too. Just installed firmware update so will see how it acts.
    Just ran speed test and now speed is half what it was and hale what the WIFI modem the extender is hooked to is putting out. Is the normal? I seem to remember my extender putting out pretty much what the main modem did. Does this have to do with the update?
    Thanks!!
  • Same thing happened to me. I updated the firmware, my connection light is a steady RED now and my link rate went from 40mbps to 11-14! :mad:
