RP1
Nov 07, 2014Follower
WN3000RP (N300) : No Internet Connection - Virgin Superhub (Netgear)
Just spent the best part of a day (including two hours on the phone to Netgear Tech Support) trying to solve the following problem during initial setting up of the WN3000RP - hope this solution helps ...
Wildlass32
Sep 29, 2015Aspirant
Hi RP1
Have you sorted your issue now? i got my new extender on Sat an i spent all day and night plus all the next day trying to get it to connect regards to the instructions with WN300RP- my advice to you cast them aside. make sure extender is less then a few feet from router reset router by unplugging and also taking out from back of router count to 30 seconds plug back in wait for it configer/setup press big button don't hold it as thats what turns wifi off, will flash or should rapidly to red/blue go over to extender and press wps just push let go make sure its not the power or will have to start again and all being well the 3 buttons should be nice and bright on. big router button will be red or half and half and then turn solid blue. good luck..
