enanpogi's avatar
enanpogi
Follower
Aug 16, 2014
WN3000RP need help badly
Hello and good day.. im just new here..
im from dublin ireland..
i have a problem in setting up my WN3000RP wifi extender
here's what happen..
i already reset the repeater to factory settings.. and then my computer already found the name NETGEAR_EXT but when i try to connect it says limited access and the wifiext.net is not working.. im really annoyed on what happen with this.. please please help me please..:mad: :mad: :mad:
1 Reply
  • Hello my Friend.
    Yes, Your computer has found the Range Extender, but if You have done nothing else, the Range Extender has not connected to Your main Router yet.
    You need to tell Your new Range Extender which Network (SSID) You want it to extend.
    You have to log into The Range Extender and pick the SSID You want it to Repeat. Provide it the WIFI password You need when You connect to Your main Router. That should be it.
    Your NETGEAR_EXT should now be online with the same password as Your main Router.
    Try it :)
    ChristianS
