ieesh
Jun 03, 2013Follower
wn3000rp no net access
i purchased dir 505 but could not use it as a repeater so i bought a wn3000rp and i tried everyway to connect it as a repeater or access point but it just shows unidentified network and will not give ...
charm
Jun 03, 2013Novice
with your dell laptop u can turn off the wireless utility.
however, lets make sure the extender is installed properly:
> plug in your extender
>with your laptop connect to NETGEAR_EXT network
> open up a browser
>NETGEAR ginie will automatically pop up
-if not, type in the address bar mywifiext.net
>just follow each step as it will show you there
>last thing is you will be connecting to your main network name with _EXT
leme know if this helped. :)
> open up a browser
