Zeus701
Jan 12, 2013Aspirant
WN3000RP PC to Extender
Bought this and haven't had any luck getting it connected. Shows connected to my D-Link router using the D-Link setup but there is no light on the WN3000RP for the PC to Extender. All other lights show solid green. Does not connect my television or blu-ray. They do connect without the WN3000RP but very low signal strength. Have tried checking it using the netgear_ext, page doesn't come up in browser.
- jmizoguchiVirtuosoMake sure placement of the extender is not where you had low signal.
You need to place between a-b point
Used below tool and fins good spot with laptop
http://www.metageek.net/products/inssider/ - Zeus701AspirantPlaced between PC and television, approximately 10 feet to extender and 10 feet to television. tried to setup with extender approximately 5 feet away, same problem. the site you give says needs wlan config running, find no such animal on my system.
- jmizoguchiVirtuosoYou need wireless PC to run the utility
If you can make work that close to that then may not like to work together with dlink - Zeus701Aspirantoh great, these people get offended when you question the integrity of their products. censoring is not cool.
- jmizoguchiVirtuosoIf you need help then be humble or find other place for answer
- Zeus701Aspirantyou're right, I will be humble with the use of my money and let everyone I know that Netgear equipment is useless
- jmizoguchiVirtuosoRanting would just make you look bad. Keep your personal anger to yourself
