Hyperspectralma
Dec 24, 2011Aspirant
WN3000RP range extender -- connecting to FIOS Actiontec MI424WR
I connect to Netgear_EXT, open the browser, connect to mywifiext.net, go through the entire process of connecting to the Router, everything goes smooth, I finally connect to the mySSID_ext and go thro...
taoofpu2
Dec 27, 2011Aspirant
THANK YOU! That solved my problem. Whodda thunk? It clearly implies you should enter your passphrase then use the generate button. Your solution worked! :)
