Tigerlsa
Aug 17, 2016Follower
WN3000RP range extender connecting to New U-Verse internet modem
Having problems connecting my WN3000RP range extender connecting to New U-Verse internet modem. Can someone assist? The U-verse router (NVG589) has no connector button as the older ATT routers did. Thanks.
- DarrenMSr. NETGEAR Moderator
Hello tigerlsa
Make sure the router security is set to WPA2 and try changing the wireless channel then try to connect the extender.
DarrenM
I believe the WPS button on the NVG589 is on the front, below all of the LEDs, as shown here.
You will need to make sure that WPS is enabled. Log into the NVG589 and you will find it under the wireless settings.
