TheShaggyDA
Dec 30, 2011Aspirant
WN3000RP range extender, DG934G router, strange behavior
Greetings. Just bought a WN3000RP to provide better WiFi coverage at the back of the house. The router is a Sky branded Netgear DG934G which we've had no problems with. Setup was straightforward, s...
TheShaggyDA
The router is using SSID, the extender is SSID_EXT, as per setup. If I connect via the router wirelessly, all is well. If I connect another device via the router, all is well. If I then connect via the repeater, the router freezes. It happens the same way if I do it the other way around - connect via the repeater, AOK. Connect another device via the repeater, AOK. Connect via the router, router freezes. I can only connect all devices to the router, or all devices to the repeater - not a mixture of both.
