ScotY
Jul 09, 2011Follower
WN3000RP range extender setup trouble
Hello, I'm hoping someone can help me with my setup. I just picked up an WN3000RP and can't get it working. My wireless router is a Belkin N+ and I'm using WEP security. Please keep in mind I am...
Radioman1017
Dec 30, 2011Aspirant
Strider08 wrote: If you are using WEP on your router, you need to put your network key or wireless password on the key 1 box of the extender instead of the passphrase. The passphrase on NETGEAR is different with the passphrase on your Belkin router. So you need to put in your 10 or 26 character code on the key 1 box of the extender wizard.
I'm having the same problem. My wireless light on the Belkin router is flashing indicating a problem with the wireless. After about an hour, I got the PC to Extender light to go solid but neither my PC nor Xbox will connect to it with Internet. I keep getting stuck on the "you're one step away from completing the installation" page.
I don't understand what Strider means by "10 or 26" character code.
I logged into the router and added the WPS pin manually, but that didn't do anything. Or at least I don't think so. Like I said, I have four lights right now but nothing will connect.
Mark
