Roon's avatar
Roon
Initiate
Nov 04, 2021
WN3000RP Reconnect with secure connection
I previously connected this extender in 2012 and used it for a few months. I reset it to factory default. I have now only able to connect it unsecured to my R7000. I do not know what Authentication o...
  • plemans's avatar
    Nov 04, 2021
    the extender should work fine with that bulb.
    Are you setting it up using wps or using the installation assistant?
    I'd recommend using the installation assistant. during setup, you can setup security on the extender.
    You can find guides, manuals, firmware, all here:
    https://www.netgear.com/support/product/WN3000RP.aspx
