Mekawi44
Feb 27, 2017Aspirant
WN3000RP v1
Can someone tell me if I can configure wn3000rp as an access point by connecting to my router using Ethernet cable? If not what would be the cost effective extender to support this function? Thank yo...
- Mar 01, 2017
Yes the option is on the V1
DarrenM
DarrenM
Mar 01, 2017Sr. NETGEAR Moderator
Hello Mekawi44
Yes you can under the Advanced wireless settings you can click a check box to make it a AP and then connect it via ethernet.
DarrenM
