Tulika
Apr 17, 2020Tutor
WN3000RP ViH2 Extender
I have changed my wifi/ service provider. However my extender is set for the old provider. How do i reset it to pick up the new provider?
Apr 20, 2020Guru - Experienced User
I guess I'm confused.
The router assigns ip addresses handles dhcp. the extender is basically acting similar to a phone/wireless device in that it just gets an ip address from the router and then passes data.
When you connected the extender, the connection didn't work.
When you disconnect the extender, the connection still doesn't work.
If the extender was the issue, disconnecting it would fix the problem.
Seems to point to the router being the issue.
