kiwimike
Apr 28, 2013Aspirant
WN3000RP WiFi Extender issues (another!)
Hi, I am unable to access the internet when I connect to my WN3000RP WiFi Extender. Here is my set up: WN3000RP V1.0.1.34_1.1.46 WPA2-PSK [AES] Region Australia ...
charm
Apr 28, 2013Novice
Hi!
I understand. Setting up the extender initially, you should not set your computer to static. This is to let both obtain a dynamic IP. Once, the installation is done and you were able to connect, that's the time you can set back whatever has static IP.
I hope this could help.
