kiwimike
Apr 28, 2013Aspirant
WN3000RP WiFi Extender issues (another!)
Hi, I am unable to access the internet when I connect to my WN3000RP WiFi Extender. Here is my set up: WN3000RP V1.0.1.34_1.1.46 WPA2-PSK [AES] Region Australia ...
jsebastian
Aug 17, 2013Novice
so how DO you "set up the Access Control Lists for Wireless" i have a verizon (actiontec) router and an iMac. thanks.
"Anyway I did a factory reset of the repeater, and re-set it up and ended up with the same issue.
After some more playing around I have now eventually gotten it working. What was not clear from the instructions is how to properly set up the ACL (Access Control Lists) for Wireless.
As well as adding the MAC address of each device that you want to allow connection to on both the WNDR3700 and the WN3000RP. You also have to add the virtual MAC address as shown on the WN3000RP attached devices list to the WNDR3700 router. It's a bit of a pain to have to add 3 MAC addresses every time you get another wireless device, but it seems to work."
