solimeo
Feb 10, 2013Aspirant
WN3000RP with Fios M1424-WR Rev. D Router
I am having problems setting up my WN3000RP with my FIOS M1424WR router. The network with the _XT shows up in the wireless network on my laptop, but I can't connect to it to get into the browser to a...
Retired_Member
Feb 11, 2013For first time setup, plug it in, then connect it to your computer (not your router) via a WIRED connection.
Open your browser, then try to go to mywifiext.net. It should prompt you for a User Name ("admin", all lowercase) and Password ("password", all lowercase). If you are using Internet Explorer and it seems to hang, then use either Chrome or Firefox.
It should then start the setup wizard. The first step involves selecting your network and inputting your network password.
