solimeo
Feb 10, 2013Aspirant
WN3000RP with Fios M1424-WR Rev. D Router
I am having problems setting up my WN3000RP with my FIOS M1424WR router. The network with the _XT shows up in the wireless network on my laptop, but I can't connect to it to get into the browser to a...
Retired_Member
Feb 18, 2013Try deleting the old saved connections on the tablet for both your main network and the extender, then again attempt to connect to the extender.
If that doesn't do it....delete connections, reboot router and extender, then attempt again.
Also....I don't know if I can repeat this enough....make sure you have the latest firmware installed on your extender.
