joedelaneycalp
May 04, 2020Aspirant
WN3000rpV.3
trying to connect this extender to fritzbox router. have reset it many times but router is not showing the extender. Any ideas?
May 04, 2020Guru - Experienced User
are you setting up via wps or via the installation wizard?
Which fritzbox?
What firmware is on the extender?
- joedelaneycalpMay 04, 2020Aspirant
Thanks for reply
Trying to connect via WPS
Fritz is 7650
Cannot find firmware version on extender - any ideas where/how todo this?
When I try to access upgrade to firmware on this link I cannot access file
https://www.netgear.com/support/product/WN3000RPV3.aspx#docs
Sorry Fritz 7560
- plemansMay 04, 2020Guru - Experienced User
Try running the install assistant and not wps. Not all device makers code wps the same.
