joedelaneycalp
May 04, 2020Aspirant
WN3000rpV.3
trying to connect this extender to fritzbox router. have reset it many times but router is not showing the extender. Any ideas?
May 04, 2020Guru - Experienced User
are you setting up via wps or via the installation wizard?
Which fritzbox?
What firmware is on the extender?
joedelaneycalp
Thanks for reply
Trying to connect via WPS
Fritz is 7650
Cannot find firmware version on extender - any ideas where/how todo this?
When I try to access upgrade to firmware on this link I cannot access file
https://www.netgear.com/support/product/WN3000RPV3.aspx#docs
- joedelaneycalpMay 04, 2020Aspirant
Sorry Fritz 7560
- plemansMay 04, 2020Guru - Experienced User
Try running the install assistant and not wps. Not all device makers code wps the same.
- joedelaneycalpMay 05, 2020Aspirant
Dont have an install assistant link? If you have one, please send it on.
I already have a netgear extender working but when i try to add a new extender, I keep getting asked to register as a new user. I already have the product listed on netgear site under my account. Not sure why I need to re register when I already have. Very frustrating trying to solve this.
