joedelaneycalp
May 04, 2020Aspirant
WN3000rpV.3
trying to connect this extender to fritzbox router. have reset it many times but router is not showing the extender. Any ideas?
May 08, 2020Guru - Experienced User
If its a new purchase, you can contact netgear and use the free 90 days of support from date of purchase.
joedelaneycalp
May 08, 2020Aspirant
Its not a new purchase - its about 5 years old as is the other extender I have in the house which is working fine.
Any advice as to how to fix? Surely not the 1st person in the world ot have this issue?
- plemansMay 08, 2020Guru - Experienced User
No one said you're the first person to have this issue.
but if you've done the following:
Tried setup hardwired in
tried after a factory reset
tried after re-installing firmware (in case its corrupted, a reset only removes settings)
Tried setup when the other extender was off
then you're running low on options.
- joedelaneycalpMay 08, 2020Aspirant
I'll try firmware upgrade...after that, I think you're correct, it may be past its sell-by-date
Not sure how I can do it if I can't connect it to wifi as I don't have ethernet connection on my laptop? Any help or suggestions appreciated.
you can manually download the firmware to a pc/laptop.
then hardwire into the device and you can manually install the firmware.
the manual walks you through it.
to get the firmware and manual go to
netgear.com/support/ and type in your model.
