Pwishing
Feb 03, 2015Follower
WN3000RPv2 No Internet Connection
Hi I recently purchased a WN2000RPv2 and have tried to set it up with network which has a BT WiFi Router as the connection to the internet. The automatic setup of the Extender fails to provide an I...
fordem
Feb 03, 2015Mentor
Pwishing wrote:
The automatic setup of the Extender fails to provide an Internet connection but does obtain a correct IP address (192.168.1.240). On checking the failure is because it sets up the Gateway and DNS as 0.0.0.0 .
How are you determining that this is the cause of the failure?
Unless I am very much mistaken, the extender should work with the gateway & DNS entries at 0.0.0.0 - most extenders will - provided that is not what the client devices are set to.
From a laptop (or other client) connected to the extender, ping, first the extender, and if it responds, ping the BT router - if both respond, check the ip settings on the client and make sure those are correct.
