noriga's avatar
noriga
Novice
Mar 07, 2015
WN3000RPv2 Wireless Mode question.
Hi
Just bought and setup a Wireless extender as per in subject and I have noticed that no matter I try to change wireless speed to 300Mbps, this automatically drops to 145Mbps no matter I tried to change the speed.
Is this parameter subject to conditions setup in the extender or the router I am bridgning to? My router (Billion 8800NL) has a full 300Mbps Wireless capable AP.
Just trying to understand what is limiting the speed of the AP on this bridge.
Thanks for your help and opinions.
  • I am having the same issue. Just got a WN3000RPv2, updated firmware and set it up.
    Will only connect at 145 no matter how many times I select 300.
    Device seems to work well other than this. This of course doesn't stop it from working just annoys me and I am not sure if it is reducing my overall speed.
    I have a netgear R6300 router that it is extending from so I know it connects at those speeds.
  • Were you able to find a solution? I'm having the same issue with an EX2700 extender. I looked everywhere, checked all my settings on router and extender, and I can't find any reason why I would be limitted to the 145Mbps setting.
