JacobCattermole
Apr 17, 2020Follower
WN3000RPv3 - reset extender to new router
I have reset my WiFi extender to a new router and have successfully connected it using the WPS buttons, however when I try to connect to the extender on my laptop or phone using the same password that I use for my router it says it is incorrect why is this?
1 Reply
Not all device manufacturer's code wps the same. If wps didn't work, factory reset the extender and follow the installation wizard guide and not wps.
